2D blocks on plans - lost
Hello! When I’m trying to print pdf with my plans some of 2d blocks in elements objects and funiture objects are become lost. Because of that I can’t finish my project. How to fix it? I have a latest version. Thankyou.
Hi @kreepilot,
Can you send me the model to visualarq@asuni.com so we can take a look at the issue?
Thanks,
Enric
I have sent it.
I tried raster type of printing (everything works) but vector has better quality.
Received!
Enric
Hi @kreepilot,
I’ve been able to fix the issue with the object in the top part of the plan. The problem was that the 2D block had a white solid hatch, and our vector print algorithm was drawing objects in no specific order, so if the white hatch was drawn the last, it occluded everything drawn before. Now, hidden vector output draws all hatches first, then all curves, just like normal Rhino vector output.
The problem with the two circles at the bottom is similar. In this case, the gray hatch was drawn before, so circles were not occluded. This hasn’t changed with the fix. Do you want to see those circles in the plan view or not?
Using solid hatches in the 2D representation can be problematic because VisualARQ draws 2D plans at the cut plane elevation. In the model, the two circles come from furniture objects without a 2D plan, so it is normal that these circles are occluded by the solid hatch.
Regards,
Enric
