in the WIP from 11/09, I get 2 shadows in shaded mode:
Sun and Skylight are off.
-C-H-A-R-L-E-S-
-C-H-A-R-L-E-S-
Yep, some sort of interesting phantom shadow which appears and disappears - seems almost as if the light producing it is coming from underneath…
–Mitch
Still seen in (6.0.16327.14151, 22.11.2016)…
Yep, thanks - I think this is what you get from Shaded if you turn on shadows… there are several lights in the default Shaded setup, and I guess only one should be casting shadows at all.
https://mcneel.myjetbrains.com/youtrack/issue/RH-36952
Release target 6.1?
Means, the fresh V6 will have this obvious error?
-C-H-A-R-L-E-S-
Release target 6.1 means it won’t hold up 6.0. But if the dev responsible gets to it before 6.0 gets shipped it might make it. It probably isn’t a critical bug (although a glaringly obvious thing).
