SMC2
1
Hello every one
with this file
P1804 bogue print pdf.zip
https://smc2.box.com/s/58kc2s9qywgasthevijxushwhllfdbr6
we have recently a bogue with rhino 6.
the bogue is whith pdf creator!
image on rhino 6 SR6
1 download and unzip the file.
try to print the A1H format
image generated by pdf creator.
do you have the bogu on your pc ?
pascal
(Pascal Golay)
2
Hello - printing to PDF Creator, A1 size, here is what I get-
P1804 bogue print pdf_CreatorTest.pdf (38.3 KB)
Does that look correct?
SMC2
3
Yes is correct in wireframe mode but if you test printing in rendered mod then
the printing is not correct.
regards
pascal
(Pascal Golay)
4
Got it thanks - the large detail has to be in Rendered mode. Seems to affect PDF Creator and CutePDF but not the Rhino pdf writer…
https://mcneel.myjetbrains.com/youtrack/issue/RH-46777
SMC2
5
Yes:) I have testing with rhinoPDF, the PDF is good but he have a bad resolution, even if i choose 1200 dpi
Regards
