is there an easy way to stretch compress a polysurface from a centre point. obviously with 1d scale it distorts the ends. currently i am splitting in 2 places and moving and rejoining. or to extend splitting capping and extruding surface then boolion union.
eg i have been modelling some checkouts, my boss comes along and says can i have the same but 500mm shorter, eg chopping 500mm out of the middle.
If you have “dead space” in between the ends, you might try Stretch. The ends won’t deform, but the area in between (you specify how much area and how much stretch) will stretch or condense readily.
