I can’t think/remember how to simply make a shape with these curves.
I seem to be unlearning as much as I learn.
!)!.3dm (44.7 KB)
!)!.3dm (44.7 KB)
What makes you believe that you ever knew how to make that shape?
Its not an easy shape. It is particularly difficult if you want to avoid things like singularities that may cause future problems.
One way to do it is with a loose loft.
!)!x.3dm (185.3 KB)
I’m feeling pretty thick today. It just seemed it should be an easy task. Thanks for the help. The lofting function is surprisingly useful.
You should be aware that you have created a degenerate surface.
Rhino should warn you that this is a bad object because it is likely to cause other commands to fail. Commands like offsetsrf, shell, fillets and booleans may go haywire if this surface is used.
There are limitations but it created a basic surface to work with. It depends what the shape was going to be used for.
I wasn’t trying to second guess. The loft command works but it’s nowhere close to the curve shape that was presented in the first instance.
It’s all fun and games though, no harm done
Curve Network-2.3dm (1.0 MB)
I don’t see any reason to mess with it any more than just do what jim suggests - a loose loft is perfect here.
The loft is about the same accuracy as the networksrf. The maximum deviation for the loft is .07mm and the networksrf deviates by .06mm. Both could be made more accurate but the cost is denser surfaces.
-jim
