⌘+⇧+1 triggers the command assigned to ⌘+⇧+PageUp
I’m having trouble with the keyboard shortcut of ⌘ + ⇧ + 1. I can assign a command macro to it, but when I press those keys an odd thing happens, the command macro for ⌘ + ⇧ + PageUp runs instead.
For example:
  • '_TiltView _Left is assigned to ⌘ + ⇧ + PageUp.
  • '_Plan is assigned to ⌘ + ⇧ + 1.
  • Pressing the keys ⌘ + ⇧ + PageUp results in running the command '_TiltView _Left as expected.
  • Pressing the keys ⌘ + ⇧ + 1 also results in running the command '_TiltView _Left. But it should have run '_Plan.
If I delete the shortcut for ⌘ + ⇧ + PageUp, then when I press ⌘ + ⇧ + 1 nothing happens. Even if a command was assigned to ⌘ + ⇧ + 1. I’ve tried several combinations, and whatever command is assigned to ⌘ + ⇧ + PageUp always runs.
This happens in every model, including fresh new files from the default templates. Pressing ⌘ + ⇧ + 1 in other another application functions as expected, so it doesn’t appear to be a broader problem than Rhino.
Any ideas about what might be causing this?
SystemInfo
Rhino 8 SR28 2026-2-10 (Rhino 8, 8.28.26041.11002, Git hash:master @ b7874a05a6982d0419fcc4f6009b510b48a09cb3)
License type: Commercial, build 2026-02-10
License details: Cloud Zoo
Apple macOS Version 15.7.3 (Build 24G419) (Physical RAM: 48GB)
Mac Model Identifier: Mac16,8
Language: en-US (MacOS default)
.NET 8.0.14
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M4 Pro
DELL U2723QE (1920 x 1080 @ 60.00Hz)
Color LCD (1512 x 982 @ 120.00Hz)
GPU Vendor: Apple
USB devices
Realtek: USB 10/100/1000 LAN
Apple Inc.: Apple Keyboard
Realtek: USB2.0 HID
Generic: 4-Port USB 2.0 Hub
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswift_math.dylib
/usr/lib/swift/libswift_signal.dylib
/usr/lib/swift/libswift_stdio.dylib
/usr/lib/swift/libswift_time.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftunistd.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftDataDetection.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/username/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/Enscape.Rhino8.Plugin.rhp “Enscape.Rhino8.Plugin” 4.14.0.668
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.28.26041.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.28.26041.11002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.28.26041.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.28.26041.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.28.26041.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.28.26041.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.28.26041.11002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.28.26041.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.28.26041.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.28.26041.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.28.26041.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.28.26041.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.28.26041.11002
I can repeat this and I’ve created a ticket here for it. Really weird. I’ll look into it. Thanks for reporting @Anthony_Esau :slight_smile:
I appreciate you checking it out @CallumSykes. Thanks!
