1.1m Terrazzo Cross - Golden Ratio
A local church requested local blacksmiths, stone masons, architects and designers propose some ideas to replace nine apex crosses which are missing. It’s quite a small budget: £650 for the maquette and only £1,500 for the final submission which should just cover costs…
This project is designed to a super tight budget, hence its stark nature, but that in itself is quite appealing. The idea that this will be here long after we’re gone is the main driver, if I’m honest.
3D model here: https://terrameasure.nira.app/a/B09lRhQqR12h-ckxJYKHww/1
First example:
In location:
Basic drawing without inner detail etc: 347_008_24-06-26.pdf (207.1 KB)
The Terrazzo Apex Cross
The site of St Laurence’s Church has been a place of gathering and worship for many
centuries, long before the present building took shape. Early stone crosses often marked
such meeting places in the landscape. The Terrazzo Apex Cross has been designed with
a form that consciously echoes these ancient stone crosses, reaching back to the deeper
history of the spot itself.
Over the generations the church has been built, rebuilt, and lovingly cared for, from its
medieval tower and spire through Victorian restoration and into the present day as a
centre for peace and the arts. The new cross at the apex of gable two continues this
living story. Its shape and proportions honour the long tradition of sacred markers while
speaking with a clear, contemporary voice.
Proportion and Place
The design began with a single practical decision: “what is the smallest cross-section that
could be reliably cast and polished in terrazzo while ensuring it would endure for
generations?”
It was a square of 100x100mm.
From this modest starting point, every dimension, the arms, the central boss, the circular
elements, and the overall proportions, was developed strictly according to the golden
ratio. Every major element has been derived directly from the golden ratio.
The cross was tested on three other gables using accurate 3D models. When the model
of this particular gable, the one bearing the statue of St Laurence, was opened, the cross
fitted almost perfectly, to within a few millimetres, exactly where it now sits. No
adjustment of scale was required. The proportions generated from that single
100x100mm square aligned with the architecture as if they had been measured for this
spot from the beginning.
The golden ratio has long been called the “divine proportion,” believed to reflect an
underlying harmony in creation. Here, the same ratio that guided the form of the cross
also brought it, almost unbidden, to the precise place where a statue of St Laurence
already stands; the saint whose halo is echoed in the bright stainless steel rings.
Terrazzo: A Material with Deep Roots
Terrazzo has deep roots in ecclesiastical building. While the technique we recognise
today was developed in fifteenth and sixteenth-century Venice, where mosaic workers
began recycling marble offcuts into durable polished floors, its ancestry reaches back to
Roman composite stonework and even earlier practices of embedding stone fragments
in a binding matrix.
In Italy, terrazzo found particular favour in churches and cathedrals. Its combination of
strength, beauty, and the ability to form intricate patterns made it ideal for floors that
would endure centuries of processional use. The material reached Britain in the late
nineteenth and early twentieth centuries and has been widely used in both Anglican and
Catholic churches for nave and chancel floors, baptisteries, and memorial elements.
Traditional terrazzo used a lime-based binder. Contemporary systems build upon this
heritage through more advanced binder technology, enhanced with carefully selected
mineral additives and pozzolanic materials. These refinements deliver significantly
greater long-term strength, density, and resistance to weathering, qualities that make
modern formulations particularly well-suited to exterior applications. The terrazzo chosen
for the Terrazzo Apex Cross draws on this long tradition while benefiting from these
advancements in material performance.Polished and Weathered Surfaces
The cross has been designed with a deliberate contrast in surface finishes. The front and
back faces are highly polished. This reveals the rich colour and crystalline structure of the
green granite aggregate within the terrazzo, giving the principal elevations a luminous,
jewel-like quality that will catch and reflect sunlight throughout the day.
In contrast, the sides and other faces are left unpolished. Over time these surfaces will
weather naturally. Lichen, moss, and other biological growth will gradually colonise the
stone, developing a soft, living patina. This natural process will help the cross blend
harmoniously with the existing stonework of St Laurence’s Church.
The bright 316 stainless-steel rings have been chosen for their exceptional corrosion
resistance and longevity. They will retain their reflective quality for many decades,
potentially a century or more, continuing to catch the light and serve as a quiet, enduring
beacon high above the people of Stroud.
Craft and Meaning
The making of the cross follows principles close to those of the Arts and Crafts
movement, a tradition that valued honest materials, skilled handwork, and beauty rooted
in tradition. The use of terrazzo, the careful application of golden-ratio geometry, and the
thoughtful contrast between polished and weathering surfaces all reflect an artisanal
approach that respects the past while creating something enduring and meaningful for
the present.
In this single object, many threads of the rich tapestry of St Laurence’s Church are drawn
together: the ancient meeting place, the long history of worship and renewal on this site,
the memory of St Laurence himself, and a contemporary expression of craft and care.
Whether the near-perfect fit on this gable is simply fortunate coincidence or something
more remains open to each person’s reading. What is clear is that the cross does not
merely sit upon this gable. It seems to belong there, as though the proportions and the
place had been waiting for it across the centuries…
WIP Maquette 1:2 scale
(Big thanks to www.terrameasurement.com for a usable 3D model of the church)
Note: Do fill 3D models with expanding foam for strength… Do not! Leave them in the car on a hot sunny day while you’re in a meeting…
If you ever need CMYK vinyl prints at very low cost for your projects, I can highly recommend www.toughcad.co.uk
£13 for 3x A2 full colour prints on PVC - delivered:
Awesome project and history!
Very meaningful :latin_cross:
Thank you. I wanted copper rings, but 3x 5mm 316 stainless rings, water jet cut is around £350 and in 5mm copper it’s £1,850. Even if I get the rings copper plated to 100 microns it works out at around £500 per ring, so back to £1,800ish.
Stainless it is :slight_smile:
