Hi all,
Let’s say I have a file which contains DocumentData. If I import that file the DocumentData is ignored. Is that a bug or intended behavior?
I wish it would be the same like DocumentUserText which will be imported with the file.
A solution to the problem would be if it would be possible to retrieve DocumentData from a file without opening it. Is there a way to do that?
Hi Dale,
Ok, I’ll use UserText the. Its just that the structure of Section, Entry and Value would have been much more convenient for what I need just now.
