If you’re in mid-command and you want to use the equivalent of the “From” object snap, how do you type it in French (i.e. not using _From)?
The tooltip is “à partir de” - which has spaces and thus can’t be used - but doesn’t work anyway, even with quotes. All other one word osnaps work correctly in French - ‘fin’, ‘milieu’, 'centre", etc. My feeling is something needs to change here, and for me the correct term would be ‘depuis’…
–Mitch
