_FilletEdge. (in macro "SetAll" not woks)
Hello everybody!
I’m trying to create macro commands for _FilletEdge
If during the execution of the commands I change the radius to all fillets
then usually I choose SetAll and enter a right value
for automatic I wrote macro as follows:
_FilletEdge
_Pause
_Pause
_SetAll
but SetAll attribute is unknown
another macro:
_FilletEdge
_Pause
_Pause
_Enter
_SetAll
This macro works almost as I want
SetAll recognized but is selected only one edge.
It does not give a choice to continue
I understand that there is activated _Enter
But without _Enter the SetAll remains unknown.
Why is this happening?
Maybe there is an idea?
Your first macro works just fine on my side. Check for typos or tell us your Rhino version.
Hi 0netech!
I use R5 64 SR13
I tested it with R5 32 SR5
If I select one edge, the macro works well.
But when I select two or more edges. - still fails
Command: _CommandHistory
Command: _FilletEdge
Select edges to fillet ( ShowRadius=Yes NextRadius=4 ChainEdges PreviousEdgeSelection ): _Pause
Select edges to fillet. Press Enter when done ( ShowRadius=Yes NextRadius=4 ChainEdges ): _Pause
Select edges to fillet. Press Enter when done ( ShowRadius=Yes NextRadius=4 ChainEdges ): _SetAll
Unknown command: _SetAll
Maybe it is a bug?
And what version are you using?
Hi Leex,
Does a macro that immediately asks for the radius work for you?:
_FilletEdge
_NextRadius
Otherwise, here are a couple of threads concerning macros with multiple successive selections:
Steve
I take my words back. When I box-select multiple edges it works as supposed to. Picking edges one by one, and clicking or pressing Enter afterwords just executes it without stopping. (V5 SR12).
@spb I think nailed it.
Shouldn’t this be _SelAll?
no, _SelAll it is a different command
Within the _FilletEdge there is a dialogue. It SetAll
I tried MultiPause
But the number of pauses sets a limit on the choice of the edges
For example if you make a 3 pauses when the two edges can be selected to load _SetAll
If four pause when _SetAll triggered for three edges is selected
_FilletEdge
_Pause
_Pause
_Pause
_Pause
_SetAll
_FilletEdge
_NextRadius
@spb I think it a way
But why multi pause does not behave as usual
_MultiPause is a scripting command available in V6, not in V5.
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#information/rhino_scripting.htm?Highlight=MultiPause
