Writing XML files with RhinoPython?
Hi…,
is there an example to write XML files with RhinoPython?
Thank you very much
Michael
www.flexiCAD.com
I don’t think there is anything special about XML writing in RhinoPython. You should be able to use the default XML tools in the Python standard library or an external package.
See https://wiki.python.org/moin/PythonXml
Hi menno,
thank you for this link. I am new to RhinoPython. I’ve got copied a XML example to RhinoPython with this line
from elementtree.SimpleXMLWriter import XMLWriter
but got at once an error message “no module named elementtree.SimpleXMLWriter”
Any ideas?
Thanks
Michael
Hey Michael, you might as well take a look into this thread.
c.
Hi clement and @stevebaer ,
yes, I’ve seen this. Steve wrote there will be better XML Python support in SR6. I’ve tried Steves example, but I didn’t get it to run.
Hm?
Thanks
Michael
www.flexiCAD.com
Hi Michael, you´ll need to add indents (4 spaces or 1x tab) below the definition if this error comes up. To do this, select the content from line 6 to 11 and press tab key once. Also line 14 needs one indent (4 spaces or 1x tab), does it work ?
import clr
clr.AddReference("System.Xml")
import System.Xml
def XMLTest():
    filename = r"C:\xmltest.xml"
    xmldoc = System.Xml.XmlDocument()
    xmldoc.Load(filename)
    items = xmldoc.SelectNodes("data/items/item")
    for item in items:
        print item.InnerText
if __name__=="__main__":
    XMLTest()
c.
Hi clement,
first of all, thank you for your time. I didn’t now anything about indents, I know brackets in all kind of forms from C++, C#… :wink:
OK, this problem is solved, but it still doesn’t run. Hm?
Michael
Hi Michael,
this seems to work here, make shure to not save the xml file in the root directory and note that uppercase and lowercase counts:
import clr
import System.Xml
def XMLTest():
    filename = r"C:\Users\Clement\Desktop\XMLTest.xml"
    for item in items:
    XMLTest()
the result should look like this:
…oh yeah, and not to forget semicolons at the end of each line :blush:
c.
Hi clement,
you helped me out, now I’ve got it to work, silly me; :wink:
I hope I can now program something usefull.
Thanks a lot and cheers
Michael
Hi XML-fans,
I am new to XML and Python scripting in Rhino, but it is easier than I thought. Here my working example:
# xml import
import clr
import System.Xml
def XMLExport():
    #prompt the user to specify a file name
    filter = "XML File (*.xml)|*.xml|All files (*.*)|*.*||"
    filename = rs.SaveFileName("Save XML file As", filter)
    if not filename: return
    xmlWriter = System.Xml.XmlTextWriter(filename, None)
    xmlWriter.WriteStartDocument()
    xmlWriter.WriteStartElement("car")
    xmlWriter.WriteElementString("name", "Jaguar")
    xmlWriter.WriteEndElement()
    xmlWriter.WriteEndDocument()
    xmlWriter.Close()
    XMLExport()
Thanks and happy times
Michael
