Hi everyone,
I am trying to write a text file in Rhino. Afterwards I want to run an external program with that file.
var text = new List<string> {"first line", "second line", "third line"}; System.IO.File.WriteAllLines("test.txt", text); Process.Start("program.exe", "test.txt");
This sequence runs perfectly in the debug mode in Visual Studio. But if I try the command in the release version it does not work.
Here is an entire exmaple that shows what I want to do:
public class CommandWriteTextFile : Command { static CommandWriteTextFile _instance; public CommandWriteTextFile() { _instance = this; }
public static CommandWriteTextFile Instance => _instance;
public override string EnglishName => "WriteTextFile";
protected override Result RunCommand(RhinoDoc doc, RunMode mode) { var text = new List<string> {"first line", "second line", "third line"}; System.IO.File.WriteAllLines("test.txt", text); Process.Start("carat.exe", "test.txt"); return Result.Success; } }
What am I doing wrong here?
Thanks for your help!
Tobi
