Just wondering if there are any hacks that can help reduce file size. Quite often i need to send a file to someone on a slow mobile connection where every MB counts.
Does iRhino just import render meshes? Would converting copied objects into blocks help?
Hi
Blocks won’t help.
Since iRhino display meshes and render meshes, I would make meshes with a few facets as you can tolerate (this may take some experimentation), and export just those minimalist meshes to a new file you’ll send to the iRhino user.
I’d open it in Rhino first to be sure the colors are all as you expect.
Textures take a lot of file space in the 3dm file. Sometimes I export as 3DM by selecting save small, save geometry only and untoggle texture and other data. You can make a fast button for that.
this is working for obj as an example.
! -_Export _GeometryOnly=_Yes _SaveTextures=_No _SaveNotes=_No _SaveSmall=_Yes
"X:\FromRhino\mesh.obj"
VertexWelding=Unmodified YUp=Yes enter enter
