This is an old wish, but I’ll repeat it once more… I would like the copy command to remember the previously used value - also MacRhino, of course.
Thanks!
Philip
Thanks!
Philip
Hi Philip - do you mean the value used the last time the command was used, or the last copy in the current command - 'cause there are command line options for the latter - I’m sure you’ve seen them but just in case…
Yes, the value used last time ‘copy’ was used. I know the command line thing (even if I forget it from time to time - I don’t use it so often)
Philip
Hi Philip - I am pretty sure we tried this, with Move as well, and it does not work well - there is some change that it causes and which I do not recall right off hand, and it turned out not to be worth the pain. Not that is could not be done eventually, but with the current command line system it did not work well - I’ll see if I can dredge up the details.
Ok, I see. Move does remember the last value though and it works well.
Philip
