I want to run a method until right mouse button is clicked. how can i do this?
-Eivind
-Eivind
What exactly are you trying to do?
# Local smoothing
def SelectBrushSmooth():
rs.Command("_-SelBrushPoints", False)
grips = rs.SelectedObjectGrips(objectId)
importCommand = "-_Smooth " + " -_Enter"
rs.Command(importCommand, False)
rs.UnselectObjectGrips(objectId)
#While loop inside main method
while True:
SelectBrushSmooth()
if scriptcontext.escape_test(False):
print "ESC pressed "
break #get out of the loop
I want a way to cancel this scripted tool for local smoothing. if i hold down esc or press it mulitple times, so it first exits SelectedObjectGrips and then the while loop.
i just want a better way to exit the loop or if anyone has other ideas i have not tested. i am normaly up for anything! since it is the user experience that is important.
