Hi, I’ve upgraded from Mavericks to Yosemity with a clean install.
This has caused me to lose all my settings in Rhino. I cannot find a way of getting my old settings back. I’ve tried copying Application Support files and tried copying the Preference files.
My old viewport settings that I had so carefully designed also disappeared… Is there a way to find back my old settings?
Hi Jeff, just wanted to let you know that putting back an old plist file to restore settings can be a bit difficult on Yosemite (and maybe Mavericks too)…
But, when you then put in the old backed-up prefs file in the correct directory, I noticed that I had to quit the following process in the activity monitor:
cfprefsd
After killing the process, quickly paste the plist file into the dir and then you will see cfprefsd pop up again after a couple of seconds. Then when you open up the software, it will use the desired plist file instead of using an empty one.
