What about square pipes
just say yes
Hi Ryan- How would you orient the square? For now, the workaround is - select a round pipe (un capped) and ChangeDegree in V to 1.
let’s not get bogged down with the details pascal.
haha
I guess you have a type-in or gizmo for setting degrees off vertical at various points along the path if that’s desired… Same way you change pipe diameters along the path.
I think what would be magical. is to have, something similar to sweep Modifier in 3D Max.
Yes, use Grasshopper.
If you want a definition to show how, let me know… probably only a few components are needed.
A couple of scripts are mentioned here…
Square pipe built into Rhino would be most excellent. ChangeDegree does not work for a polysurface. Orientation of the square could be default perpendicular(normal?) to the line and oriented on the z-axis. The rotation could be added with a degree input? Something along the lines of sweep1? Avoiding the hassle of drawing, then orienting the rectangle?
8 years later & this would still be super useful!
All of those staircases I build…
