It does not work, example from Rhino Python:
obj = rs.GetObject(“Select object”)
if obj:
index = rs.ObjectMaterialIndex(obj)
if index>-1:
rs.MaterialColor( index, (127, 255, 191) )
As material from selected object is default then nothing happened, this is correct. When material is not default, the color is changed to (127, 255, 191), this is correct and displayed also in the rendering. But the in the properties page the object material properties do not change.
Do i something wrong or is this not possible, to change the material color?
( skills beginner in Python and RhinoPython )
