I use VCarve to generate code for my cnc router. I’ve draw something in Rhino that is a simple 2D cut. I’ve exported the file as a dxf, a dwg and an ai. I’ve tried both opening directly in Vcare and bouncing it thru Corel to turn it into an eps before opening in Vcarve.
Vcarve will open the files, but it sees what should be one simple continuous cut as 20 smaller cuts, all with their own starting and stopping point.
There has to be a simple solution to this, I just have no idea what it is.
thanks
