Any idea??
Update:
After playing around on V-ray, this seems a random behavior. Can be ignored for now…
Any idea??
Update:
I removed the (SOLVED) from the thread title, as this behavior is still around. Would love to see this get resolved.
I believe this issue was also resolved with the solution in this post:
This can be easily produced by importing .vsr? (Vray material format.)
Will update this thread when I use Rhino and V-ray next time…
I am still getting window freezes with the latest update. Only with the material editor thus far, and not the Options yet. Most seem to occur randomly, but one happened when a render completed and I was a couple levels deep in editing a material. Eventually, switching between windows I was able to close the specific material popups, but could no longer get focus to the material editor. Again, it’s like there’s a hidden modal popup that can’t be found, and doesn’t come up when alt-tabbing through windows.
Edit - I still have a feeling it might be linked to autosave, I’m going to turn off Rhino autosaves and see if I get any more freezes.
I have the solution.
Search for “vrayforrhino.ini” in: C:\ProgramData\ASGVIS (program data is a hidden folder)
open It with wordpad, scroll down until you find
[Licensing]
gui_timeout_minutes=5
Change the value from “5” to “-1”
Problem solved…
Wow, I hope that is it, will try that. Thank you.
@matt_newberg Are you aware of this setting being problematic?
Yes disabling the gui_timeout_minutes can resolve freeze issues for some users. People that share a network dongle will still need that setting turned on.
Thanks for the reply. I hope for other users’ sake a fix is being worked on, or at least defaulting to the disabled setting for non-network dongles, because that is certainly a serious bug.
I haven’t had a freeze again yet, will update if I do.
Sounds good, thanks. While I’ve got your ear, any chance of VrayEnvironmentFog making it into 3.0 for Rhino?
