I’m having some trouble getting this python script to work. In brief, in want to be able to select a subset of grip points from a mesh object, and move them all so their z coordinate = 0 (either manually or automatically). I’ve tried a number of variations but can’t seem to get the right way to give the selected grips to the _SetPt command. Any ideas? Thanks in advance.
Grips need special treatment when selecting via scripting.
The most siple solution is to let rs.GetObjects select the objects picked.
next you can run the command without the need of an additional selection procedure:
