I can’t open the illustrator file (is .ai) …I’ve need to convert into DWG or DXF …
I’ll post the files “step-by-step” for show you the steps I did:
Step 1 - Open the DWG file exported from illustrator
STEP 2 - Explode the surface (for delete the surface)
STEP 3 - Here is After explosion and delete the surface
STEP 4 - Convert Curves in Arcs
STEP 5 - Appear the Preview of Arcs
(after that, in “info” appear: polycurve closed with 293 segments of curve")
STEP 6 - Details of the “info” on the left
STEP 7 - This is how apper after “Done button” for the conversion
after that…I save like “DWG” in “2004 Natural” …but, if I save it in “2004 Lines & Arcs” the problem is always the same: a lot of lines connected but split.
They send me a file for show me how they need the file:example.dwg (1.5 MB)
