Alan
April 23, 2014, 9:52am
1
Continuing the discussion from Objects are displayed wrong in rhino viewport :
My display went wrong also.
The wireframe mode is ok but shaded or rendered are not. The shaded mode settings are set to default. Here is a picture in shaded mode:
If I export this object (block) and open the new file, it displays well:
If I draw fresh new objects, the problem remains;
I have tried without success RefreshShade and ClearAllMeshes.
Willem
(Willem Derks)
April 23, 2014, 10:35am
2
Hi Alan,
You might want to try the solution proposed in this topic:
This happened to me before, too. This time it happened after I mirrored a group of objects. In shaded view I see too many edges, objects that aren’t supposed to be visible, etc. What can cause this? Any workaround?
[image]
HTH
-Willem
Alan
April 23, 2014, 12:34pm
3
Thanks Willem. Playing with the testZBiasFactor (increasing or decreasing) arrange the display.
Now I can clearly see that, when zooming, I have a cutting problem too !
