Hi All,
I’m having trouble modifying a design. I would like to extend the length of only the top part of the polysurface, so I have cut it in half with a cutting plane. However, when I try scale, as I extend it 5mm, it also makes the base larger so it no longer matches up to the other half. (Perhaps the non-uniform scale would work but in all my attempts it didn’t, and figuring out which value affected what and how got the best of me).
So I tried stretch, which worked almost perfectly, as it maintained the base the same size so it fits with the other half still, but it ever so slightly makes the new polysurface dip, whereas before it was a straight, not concave, surface. Maybe I’m just putting the stretch axis in the wrong place or something? I’ve been staring at it so long now I think my brain’s a little fried and I need some new eyes
Any suggestions welcome. Thanks
before (you can see the black line is the cutting plane):
and after, where it now curves in a tiny bit:
