This is a little pick, but everytime I start up Rhino I will get the command “select target objects” and I will have to escape out of it. I look thru the commands and don’t see any start of a command. I have several things that load at start such as VRay, Bongo. Thanks. ;
Look in Options>RhinoScript>“Script files to load…”. If there’s nothing in there either, you may have loaded some script disguised as a plug-in which is why you don’t see it in your startup scripts box… In which case you’ll need to figure out which one it is…
–Mitch
You probably have a Rhino script that is set to load at startup but is not actually set up for that, or possibly a startup command.
Found it, thanks.
