Split Mesh Returns Nothing
I got a part of a plugin that doest work somehow.
If it doesnt split I return the original but it also says it does not exist. Sometimes. Not always
  • Extrude is a Solid
  • Mesh is to trim Mesh
Private Function CreateTrim (Byval Mesh as geometry.Mesh, Byval Extrude as Guid)
Dim NewSrf As Geometry.Brep = New DocObjects.ObjRef(Extrude).BrepDim ElementObjRef As New DocObjects.ObjRef(Mesh)Dim ElementMesh As Geometry.Mesh = ElementObjRef.MeshDim Splitted As Geometry.Mesh() = ElementMesh.Split(Rhino.Geometry.Mesh.CreateFromBrep(NewSrf))
Dim MyMesh As Guid = Mesh
If Splitted IsNot Nothing Then
                                For Each Splits As Geometry.Mesh In Splitted
                                    If Splits IsNot Nothing Then
                                        Dim AddedMesh As Guid = doc.Objects.AddMesh(Splits)
                                        If AddedMesh <> Nothing Then
Dim maxZMesh As Double = Functions.GetMaxZMesh(AddedMesh)  'Get Boundingbox.Max.Z
                                            Dim maxZDupplicate As Double = Functions.GetMaxZBrep(Extrude) 'Get Boundingbox.max.z
If maxZDupplicate >= maxZMesh And DocMesh.Mesh.Vertices.Count > 250 Then
                                                doc.Objects.Delete(MyMesh, True)
                                                MyMesh = AddedMesh
                                            Else
                                                doc.Objects.Delete(AddedMesh, True)
                                            End If
                                        End If
                                    End If
                                Next
If MyMesh <> Mesh Then
                                    doc.Objects.Delete(Mesh, True)
                                End If
                            End If
        doc.Objects.Delete(Extrude, True)
        Return MyMesh
        End Function
Cant get the box too work so it is a bit messy. Sorry for that.
Anyone knows whats going wrong?
Use three backticks followed by “vb” on an empty line to start VB code formattting
```vb
type code here
End with three backticks to close code formatting.
for example
Private Function CreateTrim(Byval Mesh as Geometry.Mesh, Byval Extrude as Guid)
Very easy :wink:
Oke that worked. Somehow its still a bit messy because I removed and added some enters. But for next time I know what to do.
@menno anny idea what is going wrong here?
Does it not split sometimes? Because it does run throught the
And it does return a Guid but it says it cant find the Returned Guid somehow.
I don’t know, your code is a bit messy :smile: but I do see this line
A Guid is a value type, and you should check success like this
If AddedMesh <> Guid.Empty Then 'Guid is a value type, Guid.Empty is returned when Add is not successful.
It seems it doesnt always split the mesh. Any Idea why that happens?
They are overlapping
Oke cleaned it up a bit:
Private Function TrimSides(ByVal Dupplicate As Guid, ByVal Mesh As Guid, ByVal doc As RhinoDoc)
            RhinoApp.RunScript("-_SelID " & Dupplicate.ToString & " _ExtrudeSrf _DeleteInput=Yes _Solid=Yes _Cap=_Yes _D w0,0,0 w0,0,-1 100 _enter", False)
            Dim Extrude As Guid = doc.Objects.MostRecentObject.Id
            Dim ToTrimMesh As New DocObjects.ObjRef(Mesh)
            Dim ElementMesh As Geometry.Mesh = ToTrimMesh.Mesh
                            Dim DocMesh As New DocObjects.ObjRef(AddedMesh)
                            Dim maxZDupplicate As Double = Functions.GetMaxZBrep(Extrude) + 2 'Get Boundingbox.Max.Z
                                MyMesh = AddedMesh
                            Else
                            End If
                        End If
                    End If
                Next
                End If
            End If
            Return MyMesh
End Function
P.S. its trimming in the horizontal direction not the top. Dont know if i need to rotate the screen for this…
