Some wrong Control points
i tried to read a 3DM File (from Rhino v.5.1.30129.1756, 29.01.2013), but one Row of the Control point matrix is wrong.
I used the OpenNURBS Toolkit (example_read) from version 20110202 and 20121024, but its the same problem.
But in Rhino 5 and the Step conversion the Control points are correct.
Here is a Screenshot from our System with the Step-File (red) and the 3DM-File (green).
Best regards
Marcel
I also have this issue using Rhino3dm. I can send files if needed.
Any help will be appreciated.
Hi @Mike_Johnson,
Sure, free free to post the 3dm file. Also, please provide a code snippet that demonstrates how you are reading the file and how you are determining that the control points are ‘wrong’.
Thanks,
– Dale
