The command line feedback for Smart Track is backwards. When you turn it on it tells you it’s off, when you turn it off it tells you it’s on.
Hi Mark- I do not see that here so far … What build do you have (Rhinoceros menu > about Rhinoceros)?
Anyone else see this?
Seems to work fine here from top bar and command line typing it in, even from Osnap under curser popup.
«Randy
It’s matching now. I skipped one of the builds as I needed access to the property pallette because I name pretty much everything and select by name as part of my normal workflow.
When that got fixed I grabbed the latest and it’s working correctly now.
