I modeled a motorcycle, then setup my brazil materials… now when I click the show safe frame drop down, it doesn’t show the safe frame. So I rendered the scene, then went back to Rhino. Sometimes in the past my safe frame would only show up if I rendered after I checked the option to use it. But alas, no safe frame is on the screen. Safe frame is extremely useful, any help is appreciated. I put this under the Brazil topic due to the fact that if I don’t have Brazil as the active renderer my safe frames show up for the same file.
Well apparently I wasn’t in perspective mode in my perspective viewport. I must’ve accidentally turned it off. Problem solved!
