Setting or changing the extrude curve to form surface command
I have tried to use the extrude curve command to create a surface. I have tried several ways to set the extrusion curve axis. I have tried selecting the view, I have tried selecting the axis arrow on a selected object before calling up the extrude curve to create surface command. How do you change the extrusion axis if the previewed result is not what is wanted.
Hi Mike,
there is a _Direction option in the command line, click on it after starting the _ExtrudeCrv command, then you can pick two points to set the extrusion direction.
c.
Hi Mike- use the Direction command line option, then set two points to set the direction vector.
Thanks so much. I have used the options in the command line but it has been a while. Thanks again.
