dale:
I have readed this article before,and it’t not helps.'
maybe you can try my test codes and test file in the attachment
and help me to see what the problem of my codes.
thanks
thanks dale,
this can open succcess sometimes ,but will failed sometimes too (just the same file)
when failed I see the return value of RunScript function returned,it always true.
you can’t repeat the problem by using the above sample command,because this problem just can repeat in my own plugin,my plugin is very large ,but The open igs files codes just the same as the codes you provided,maybe I think the other codes of my plugin cacese the problem,but I have no idea to find which codes has problem. this problem not happend erery time.
maybe my other codes has out ot memery error,and chang rhino obecjet’s memory
