Right Click buggy after setting Middle scroll click to PAN
Was using PAN with the Shift+mouse right key, but found that Setting to the middle mouse button was what I was looking for.
But, just found out that when I set it, the finishing command with the Right mouse button does not work anymore. When setting middle mouse button as pop-up menu, then the finish button command works again.
Any way to solve? Using Shift+mouse right for now.
I put my mac info below:
sincerely,
Toshi
Software information
Software versions
Rhinoceros version: 5.0.1 (5A858)
IronPython version: 5.1.2015.131
Language: ja (MacOS default)
OS X version: バージョン/version 10.10.3(ビルド/build 14D136)
Plug-ins
None
Third party kernel extensions
None
Hardware information
Computer hardware
Hardware model: MacBookPro11,1
Processor: Intel Core i5-4258U CPU @ 2.40GHz
Memory: 8 GB
Architecture: Intel 64 bit
Video hardware
Graphics: Intel Iris 1536 MB
Memory: 1536 MB
Screen size: 1280 x 800
Displays: カラー LCD/color LCD (227dpi 2x)
USB devices
Apple: Internal Memory Card Reader
SMI Corporation: USB DISK
Apple Inc.: Bluetooth USB Host Controller
Apple Inc.: Apple Internal Keyboard / Trackpad
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 INTEL-10.6.20
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24ビット/24bit
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 4x
Mip map filtering: なし/none
Anisotropic filtering: なし/none
Toshi-
Please let me make sure I understand…
When you have your Rhinoceros > Preferences > Mouse set to:
…using right-click to complete the command no longer works.
For example, with the Middle mouse button set to Manipulate view, if you run the _Polyline command, you cannot finish the command with the a right-click.
Is that correct? If so, I can reproduce this on my computer as well.
Hi Dan,
Exactly as you explained. Thank you for the screen shot.
Toshi
@Toshiaki_Takano Thanks for the confirmation and for reporting this. I’ve added it to our list of bugs to fix (MR-2276).
This bug should be fixed in the latest RhinoWIP.
Thnx! Sorry for the late reply.
