RhinoScript Debugging error
I am using Rhinoceros 5.0 with educational lab license. When I try to use debug the script button, I always get the same error in the following example. It gives error only when I use if statement. When I do not use if statement, debugger works well.
Here is the code that I copied from the help box examples, so there should not be any error but when I put a breakpoint and debug the script I get the following error. Thank you for your help in advance.
Option Explicit
Call Main()
Sub Main()
	Dim dblRadius, arrPoint
	dblRadius = Rhino.GetReal("Radius of new circle", 3.14, 1.0)
	If Not IsNull(dblRadius) Then
	arrPoint = Array(0, 0, 0)
	Rhino.AddCircle arrPoint, dblRadius
	End If
End Sub
What service release of Rhino 5 are you using? (Help -> About)
Do you mean this?
Version 5 SR12 64-bit
(5.12.50810.13095, 10.8.2015)
Educational Lab License
SN: 4-1502-0104-100-0000391-17012
