Rhinocommon Select Method
I am using the ObjectTable.Select(IEnumerable objectIds) method to select multiple objects in Rhino. However, the select process is very slow for a large amount of objects when the object properties page is open. It seems like the method is adding objects to selection one by one and updating the properties page accordingly. I would like to know if there is any way to avoid this behavior when selecting multiple objects.
Thanks,
Alan
Have you tried to do RhinoDoc.ActiveDoc.Views.RedrawEnabled = false; during the update?
Disable the redraw does not help.
Alan
If you are doing your selection from a modeless UI, then I suggest creating a hidden command and then have your modeless UI run your hidden command using RhinoApp.RunScript.
More info: the ObjectProperties panel is disable during the running of commands. But if your using a modeless UI, then the panel doesn’t know to disable itself.
Hidden commands are declared like this:
[System.Runtime.InteropServices.Guid("<your_guid_here>"), CommandStyle(Style.Hidden)]
public class MyHiddenCommand : Command
Let me know if you need an example…
Dale,
Thanks. Using a hidden command works.
Alan
Dale,
how would an example look like if you have either a list of all ids or a list of all objref?
Thanks
Christian
Dale,
I solved it.
using Rhino;
using Rhino.Commands;
using System.Collections.Concurrent;
using Rhino.DocObjects;
using System.Linq;
using System;
namespace Lala.Commands
    [System.Runtime.InteropServices.Guid("A3834458-E805-438C-8FC0-7987B71B0DA2"), CommandStyle(Style.Hidden)]
    public class RC_HiddenSelect : Command
        static ConcurrentQueue<ObjRef> _selObjects;
        static RC_HiddenSelect _instance;
        public RC_HiddenSelect()
            _instance = this;
        ///<summary>The only instance of the RC_HiddenSelect command.</summary>
        public static RC_HiddenSelect Instance
            get { return _instance; }
        public static ConcurrentQueue<ObjRef> SelObjects
            get { return _selObjects; }
            set { _selObjects = value; }
        public override string EnglishName
            get { return "HiddenSelectByID"; }
            try
                RhinoDoc.ActiveDoc.Objects.Select(_selObjects.ToList(), true);
            catch (Exception ex)
                throw ex;
            return Result.Success;
Thanks for the hint.
Christian
