It seems to me that the only way to get at objects worksessioned into a Rhino Document is by using RhinoDoc.Objects.FindByLayer - using RhinoDoc.Objects.FindByFilter or RhinoDoc.Objects.GetObjectList don’t seem to recognize them. Is this true, or am I missing some ObjectEnumeratorSettings filter option? If it is the case, is there a way to apply an ObjectEnumeratorSettings filter to a list of RhinoObject after already having retrieved it?
Try the following:
var filter = new ObjectEnumeratorSettings
NormalObjects = true,
LockedObjects = true,
ActiveObjects = true,
ReferenceObjects = true
var rh_objects = doc.Objects.FindByFilter(filter);
if (null != rh_objects)
foreach (var rh_obj in rh_objects)
if (rh_obj.IsDeleted)
continue;
var str = (rh_obj.IsReference) ? "worksession" : "model";
var desc = rh_obj.ShortDescription(false);
RhinoApp.WriteLine("{0} {{{1}}} is a {2} object", desc, rh_obj.Id, str);
Does this help?
– Dale
Never thanked you @dale - this worked beautifully. I was missing “ReferenceObjects” in my filter - I guess I assumed it meant something different.
Appreciate the help!
