I have a small problem using CreateBooleanUnion without tolerance. Do you think you can add tolerance to CreateBooleanUnion?
The problem is Two polyline intersect but the Boolean Union doesn’t work because the overlapping is smaller than document absolute tolerance.
I attach a command a dummy command and a 3DM file.
CurveBooleanCommandAnd3DM.zip (21.4 KB)
Thanks,
Rafa
