It took me a while to pinpoint, but this command reproduces the problem. In short, calling CommitChanges()
on a CustomMeshObject
reverts it to a normal MeshObject
. I would very much like it to keep on being CustomMeshObject
protected Result RunCommand(RhinoDoc doc, RunMode mode)
   RhinoApp.WriteLine("Run this command in Shaded mode!");
   Mesh m = Mesh.CreateFromBox(new BoundingBox(Point3d.Origin, new Point3d(10, 10, 10)), 2, 2, 2);
          Â
   MyMeshObject mesObj = new MyMeshObject(m);
   doc.Objects.AddRhinoObject(mesObj);
   Guid id = mesObj.Id;
   RhinoObject obj = doc.Objects.Find(id);
   RhinoApp.WriteLine("Type of OBJ: {0}", obj.GetType().Name); // MyMeshObject
   doc.Views.Redraw();
   string str = String.Empty;
   RhinoGet.GetString("ENTER to continue - the mesh should be gray-ish and show red bounding box", true, ref str);
   m = obj.Geometry as Mesh;
   if (null != m)
       Color[] newColors = new Color[m.Vertices.Count];
       for (int i = 0; i < newColors.Length; ++i)
           newColors[i] = Color.Violet;
       m.VertexColors.SetColors(newColors);
   obj.CommitChanges(); // this is vital to propagate the color change, but reverts the custom object to a normal mesh object
   doc.Views.Redraw();
   str = String.Empty;
   // the mesh is violet, but the bounding box is not drawn. In fact, it is no longer a MyMeshObject.
   RhinoGet.GetString("ENTER to continue - the mesh should be violet and show red bounding box", true, ref str);
   RhinoApp.WriteLine("Type of OBJ: {0}", obj.GetType().Name); // MeshObject <== why is this not MyMeshObject?
   return Result.Success;
public class MyMeshObject : CustomMeshObject
   private BoundingBox _bb;
   public MyMeshObject(Mesh m)
       : base(m)
       if (null != m)
           _bb = m.GetBoundingBox(true);
   public MyMeshObject()
       // required
   protected override void OnDuplicate(RhinoObject source)
       MyMeshObject other = source as MyMeshObject;
       if (null != other)
           _bb = other._bb;
       base.OnDuplicate(source);
   protected override void OnDraw(DrawEventArgs e)
       if (_bb.IsValid)
           e.Display.DrawBox(_bb, Color.Red, 2);
       base.OnDraw(e);
