Hi guys,
Just noticed that when using Compute method on the planar surface created from closed curve -Area property returns area of the untrimmed surface. Can you repeat it on your side?
Thanks,
Dmitriy
Hi guys,
Thanks,
Dmitriy
Can you post your code and a file with the surface in it that is not correctly computed? I cannot reproduce this problem with the code below.
ObjRef bRef;
Result res = RhinoGet.GetOneObject("Select trimmed BREP", false, ObjectType.Surface, out bRef);
if (res != Result.Success)
return res;
Brep b = bRef.Brep();
AreaMassProperties ampBrep = AreaMassProperties.Compute(b);
RhinoApp.WriteLine("{0}", ampBrep.Area);
return Result.Success;
Clarified.
Used surface instead of Brep.
Thanks, Menno.
