RhinoBrepClosestPoint issue in SR10
Continuing the discussion from RhinoSplitBrepFace problem after latest updates:
I’ve moved this to a new topic, since it is really a new topic…
This is the same bug as the RhinoSplitBrepFace bugs reported here.
This will be fixed in the next SR.
Just curious, how are you creating these surfaces? I’m pretty sure Rhino (commands) won’t let you create transposed rev surfaces…
Hi dale,
I’m not creating those surfaces and I don’t know in which program are created, we receive from the client. But when Rhino said Is Valid then we don’t care about breps :smiley:
So, when to expect the new SR?
Regards, Filip
I don’t know when to expect a new SR. But when a release candidate is made available, you will here it here on Discourse.
Hi Dale,
It was one of my test examples I created in Rhino 4. However, it could be, that we flipped the surface normal manually using command ‘_Dir’ as we often change the normal (as well as the u,v-parameters) to control the orientation of the finite elements we generate on the surfaces.
Andreas
