This is not working because in VB.net the return of the command is not an Array.
This shows Error : Error 2 Implicit conversion from ‘Object’ to ‘System.Collections.IEnumerable’.
The help file for the old .NET SDK is in the zip archive below.
RhinoDotNetSDK_20080927.zip (19.6 MB)
And this is the link to some information on the old .NET SDK.
Like I said, this works.
Protected Overrides Function RunCommand(ByVal doc As RhinoDoc, ByVal mode As RunMode) As Result
Dim rs As RhinoScript4.IRhinoScript = RhinoApp.GetPlugInObject("RhinoScript")
If rs Is Nothing Then
Return Result.Failure
End If
rs.Command("_Line 0,0,0 1,1,0", 1)
Dim results = rs.LastCreatedObjects()
If IsArray(results) Then
For Each res As Object In results
If res IsNot Nothing Then
Dim str = TryCast(res, String)
If str IsNot Nothing Then
RhinoApp.WriteLine(str)
End If
End If
Next
End If
Return Result.Success
End Function
Sorry, don’t know how else to help.
Hi Dale,
When i tried to get the RhinoScript object using your method, i dont gent the RhinoApp.GetPluginObject command
It shows RhinoApp.GetPluginObjectInterface
It gives me Error : GetPlugInObject’ is not a member of 'RMA.Rhino.MRhinoApp
Do i have to add any reference to project ??
take a look at the image posted
If you want your project to work (like my command), then you will need to add a reference to the RhinoScript type library (RhinoScript.tlb) to your project.
Yes Dale. I have added the RhinoScript.tlb to my project… but then also i am not getting option GetPluginObject.
Hi Dale,
Found the solution
Here is the code :
Dim LastObj As Object
LastObj = RScript.LastCreatedObjects()
Dim tempArray = CType(LastObj, System.Collections.IEnumerable)
For Each OB In tempArray
RScript.ObjectLayer(OB, "Layer 05")
Next
