I tried with the code below ( not sure about my syntax) the ID is returned as unknow command.
How can i do ? possible ?
Thanks.
Call Split()
Sub Split()
arrObject = Rhino.GetObjects("Select object")
If IsArray(arrObject) Then
For Each strObject In arrobject
strCutter = Rhino.GetObject("Select cutter")
Rhino.Command "_Split " & strObject & "_Enter " & strCutter & "_Enter "
' Rhino.Print "strObject ID :" & strObject
' Rhino.Print "strCutter ID :" & strCutter
Next
End If
End Sub
