Simon,
I, too, have been working on an imported file with a large number of blocks (from Solidworks). In case a somewhat similar comparison helps you narrow down your problem, here are a few differences I’ve noticed between our setups. Obviously, there may be others (such as the number of locked or hidden items?) which may be related, or perhaps it’s something entirely different, and germane to your setup (such as the Wacom)?:
Despite also having a large number of materials (2,993: which I didn’t realize were even in the file!), I have not had any of the temporary hangs during autosave.
The file size is also pretty large, at 163.6 mb.
I have less ram than you (only 16 gb) and a slower computer (MBP 17").
I am using Rhino 5.1 instead of 5.2 (and sort of wondering why I haven’t been prompted for the update, since I wasn’t aware that I was behind?).
I am using an internal SSD drive.
I am using OSX 10.10.5 (versus your 10.9.5) and it was a fairly painless upgrade.
~Dave
Audit Summary:
Table tally:
41 layers
1 dimension styles
2 fonts
2993 rendering materials
Object tally:
7964 normal objects
0 locked objects
2 hidden objects
0 deleted objects (in undo buffer)
0 block definition objects
0 reference normal objects
0 reference locked objects
0 reference hidden objects
0 reference block definition objects
No errors.
Software information
Software versions
Rhinoceros version: 5.1 (5B161)
IronPython version: 5.1.2015.131
Language: en (MacOS default)
OS X version: Version 10.10.5 (Build 14F1021)
Plug-ins
None
Third party kernel extensions
com.Logitech.Control Center.HID Driver (3.9.1)
com.Logitech.Unifying.HID Driver (1.3.1)
com.karios.driver.DuetDisplay (1)
org.virtualbox.kext.VBoxDrv (4.3.20)
com.paragon-software.filesystems.ntfs (313.2.12)
org.virtualbox.kext.VBoxUSB (4.3.20)
org.virtualbox.kext.VBoxNetFlt (4.3.20)
org.virtualbox.kext.VBoxNetAdp (4.3.20)
Hardware information
Computer hardware
Hardware model: MacBookPro8,3
Processor: Intel Core i7-2860QM CPU @ 2.50GHz
Memory: 16 GB
Architecture: Intel 64 bit
Video hardware
Graphics: AMD Radeon HD 6770M 1024 MB
Memory: 1024 MB
Screen size: 1920 x 1200, 1920 x 1200
Displays: Cinema HD (99dpi 1x), Color LCD (133dpi 1x)
USB devices
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
Logitech: USB Receiver
Apple Computer, Inc.: IR Receiver
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 ATI-1.32.25
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 4x
Mip map filtering: None
Anisotropic filtering: High
