I need to do several renderings of current view to image files. How can i do this ?
The _Render command seems not allowing parameters. Maybe i didn’t look good enough.
Parameters i need is : HorizontalSizePixels, VerticalSizePixels, FilePathAndName
All other parameters will be kept as setted by user.
Can someone help me for doing this ?
Note : I have already done some renderings by rendering the Viewport using “ViewCaptureToFile”.
But this is not what i need.
It seem’s to do what i want but the -Render call doesn’t work.
When i enter "-Render" in command line it works…but when i call it in the above sequence it doesn’t.
Even if i just call this here it doesn’t work:
