Is it on purpose if you rebuild an object that it loses its layer?
-Jordy
-Jordy
I think it depends on if the âCreate new object on current layerâ is checked. If so, the output goes to the current layer. If not, the output goes to the input curve layer.
While scripting set the parameter âOutputLayer=Inputâ instead of Current.
Hi Jordy- âCurrent layerâ in this context means the layer that is current in Rhino- the active layer - not the layer the object is currently onâŚ
Oke its working now. I unchecked it. Was a bit confusing. Thanks for the help.
