Hello !
I’m completely new into scripting, and I am trying to scale every polysurface of a rhino project from its centroid.
So far, I managed to get this:
obj = rs.GetObject("Select a polysurface", rs.filter.polysurface)
if obj:
massprop = rs.SurfaceAreaCentroid(obj)
if massprop: centroid = rs.AddPoint( massprop[0] )
center3d = rs.PointCoordinates(centroid)
rs.ScaleObject(obj, center3d, [0.9,0.9,0.9] )
As I said, I’m completely new. Now I’m trying to apply this scale to every polysurface of the file. And loops seam as a foreign language to me. If I manage to have a list with every guid of the polysurfaces, who do you I apply a transformation to each ?
You can get a list of objects by type by using the Rhinoscript function ObjectsByType. To adapt your code, you need to wrap your centroid scaling operations (the last four lines) in the for loop. Then you change the variables accordingly for the iterator and item. See the code below for a working example:
objs = rs.ObjectsByType(16, select=False) #get all polysurfaces in model
if objs:
scaled_objs = [] #empty list to store scaled objs further operations
rs.EnableRedraw(False) #disable redraw to speed up script
#start of for loop
for i in range(len(objs)):
obj = objs[i] #get polysurface at current index
if massprop: centroid = massprop[0]
scaled = rs.ScaleObject(obj, centroid, [0.9,0.9,0.9], copy=False)
scaled_objs.append(scaled) #add scaled object to list
#end of loop
rs.EnableRedraw(True) #enable redraw to finalize operation
