Hello I am trying to creat a grid of points, where only the point inside a surface should be set.
To do this I use IsPointInSurface
The problem is that I get a huge time difference depending on the setup.
Depending on the point setup I get a huge diffrence in time as show below.
point1 = [b0+x*d_x, b1+y*d_y, b2+z*d_z] 17 sec
point2 = [b0+x*d_x, b1+y*d_y, b2+z] 2 sec
Is this because point1 is more inside the surface? se the code below
Are there any way of profiling the code more in deapth? python have the profiling tool cProfile which do not work native in the rhino python
best kasper
import random
import timeit
rs.EnableRedraw(False)
surface = rs.GetObject("pick a surface")
bounding_box = rs.BoundingBox(surface)
shape = [25,25,25]
d_x = (bounding_box[1][0] - bounding_box[0][0])/float(shape[0]-1)
d_y = (bounding_box[2][1] - bounding_box[0][1])/float(shape[1]-1)
d_z = (bounding_box[4][2] - bounding_box[0][2])/float(shape[2]-1)
b0 = bounding_box[0][0]
b1 = bounding_box[0][1]
b2 = bounding_box[0][2]
a = 0
start = timeit.default_timer()
for x in range(shape[0]):
for y in range(shape[1]):
for z in range(shape[2]):
point = [b0+x*d_x, b1+y*d_y, b2+z*d_z]
if rs.IsPointInSurface(surface, point, False, 0.01):
a += 1
print str(timeit.default_timer() - start) + " sec"
point = [b0+x*d_x, b1+y*d_y, b2+z]
a += 1
rs.EnableRedraw(True)
