If I want to switch between vector and raster print in my printing dialogue my mac starts to use round about 80% CPU for Rhino across 10 minutes or more - or my Rhino Crash.
Thanks Hugo, so I have to install the WIP version? - I’m running 5.0.2, Probably being a bit thick here but doesn’t/shouldn’t the licensed version keep up with the work in progress version? Where do I find this WIP?
It’s probably a bit different for the Mac side of things at this point in time but the thought is that these are two separate tracks. The WIPs will lead to the next major version (i.e. Rhino 6) whereas the regular release will receive service releases when necessary (and release candidates thereof before final release of a SR). The WIPs can introduce new functionality but are not intended to be used in a production environment as there can be bugs and stability issues that could cause loss of data.
Bizarre - I don’t know what’s going on there… There are a couple of bugs on the web page that I see - the French language page isn’t quite the same as the English page - but it shouldn’t do that… Do you have another computer to try for the download? Have you tried to see if the English equivalent page shows the same?
It will be “less hidden” in the 5.1 update (a link will appear in the Help menu if you are in a commercially licensed version). This fix is not in the WIP…which makes sense if you think about it.
