PlaneCurveIntersection failures under RhinoScript
Under Rhino5 SR9, I’m getting some intermittent failures when using the Rhino.PlaneCurveIntersection to intersect a series of sections that were all cut from the same surface. In the example file, executing PlaneCurveIntersection under Rhinoscript fails to find an intersection on the red curve (at X=40), but it finds one on the black curve (at X=42). Under python, the command finds the intersection in both curves. There was a similar issue and bug fix for SR6 mentioned on the forum about a year ago ([Plane Curve Intersection Fails][1]). Could this be a related issue? I assume there’s no problem with the curves since the python version was working.
Thanks.
Jim
Curve split problem sample.3dm (107.1 KB) split curve.rvb (462 Bytes) split curve.py (286 Bytes)
[1]: Plane Curve Intersection Fails
Hi Jim,
This will be fixed for SR10. Thanks for reporting.
