Hello, I would like to select a surface, then to do an offset on it.
I follow the example in here but it won’t work.
surface = rs.GetObject("Select a surface", rs.filter.surface)
if rs.IsSurface(surface):
print rs.IsSurface(surface)
# Only with distance
rs.OffsetSurface(surface, 10.0 )
# With all parameters
rs.OffsetSurface(surface_id=surface, distance=10.0, tolerance=0.001, both_sides=True, create_solid=True)
print rs.OffsetSurface(surface,10.0)
My output is the following :
True
None
Which mean that I have the right surface (an Open Surface), but the OffsetSurface is in error. But I didn’t know why.
Did you have some advice to solve this problem ?
Thank you in advance.
