The offset tool does not seem to have a “loose” option like offsetsrf has (which conserves the cv structure of the original item).
Do I miss the secret trick to access this option or should I wish for it in Rhino 6?
Thank You for the suggestion, but I know a couple of ways to work around the missing “loose” option, that is not the problem.
It’s just not very convenient.
I find it strange that the option exists but not for .
If anything shouldn’t it be easier to implement for curves than for surfaces?
I have a super cool hack to ‘offset’ a curve, BUT with the exact same number of control points. It works well for when you’re more concerned with simplicity than accuracy.
Thanks a lot. I wrote a comment in said other forum. --> Link
I still think the loose option should be included in “Offset” for the reason stated in my response and for convenience.
Shouldn’t be too difficult to implement, should it? Maybe in Version 6?
I am actually hoping that McNeel will add a new option for the curve offset command. They already use the term ‘loose’ for surface offsets, so I suggest ‘same control points’ or ‘dave-flavor’
Hi!
I stumbled over this exact problem today, and found that R6 beta has a ‘Loose’ option built in it’s curve Offset command. Nice!
Just to conclude this…
Best
Eugen
